Got My MTX TA81001, check it out!
john3387
its pretty nice, i hooked it up to my current system to make sure it worked and works great. i have it out now waiting to get the subwoofer, with im thinking will be a mtx thunder 9512-44, or an fi, still in debate.
Post the birthsheet. I have a pair that both are just under 2000.. 1969 and 1983 at 1 ohm.. over 800 at 4 ohms for both.. 1400's at 2 ohms.. I absolutely love mtx for amps, just waiting to get some sundowns to compare the 2
MTX makes some decent amps. One of my favorite amps was the MTX 1501d. I still regret selling that amp. They are very solid and reliable amps in my opinion. I'm just not really a big fan of the new design thay have come out with on their new line of amps.
Nice amp though, enjoy.
well here is the birth sheet, but im sure you may not be able to read it so here are the spec:
Power at 4 ohm watts/ch
500W rated 802W measured
THD+N(DISTORTION) %
4OHM
SIGNAL TO NOISE RATIO @ 1 OHM
68dB rated measured 68dB
SIGNAL TO NOISE RATIO @ REF. POWER
105dB
FREQUENCY RESPONSE @ 1 WATT
20Hz-200Hz RATED
14.4 V
POWER 1/2 CHANNEL @ 2 OHM
3000W RATED 4042W MEASURED
POWER 1/2 CHANNEL @4OHM
200W RATED 2768W MEASURED
POWER @ 1OHM
1500W RATED 2021W MEASURED
POWER @ 2OHM
1000W RATED 1384W MEASURED
That's insanely underrated for only $270. Maybe I'll pick one of these up for an extra $50 over a hifonics 1606. Does anyone know the efficiency of this amp? I searched around on mtx, and google and couldn't find it.
The amp looks good man. I've heard a lot of good things.
john3387
john3387
Houston, TX
dman4486
