Got Anything To Trade??
Beerdrnkr
I have the following for sell or trade, let me know what you have and let's work something out!
MTX Thunder 502 2ch. amp
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 90 W x 2
RMS Power at 2 Ohms 180 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
MOSFET Circuitry Yes
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Audio Control EQx
Dual-bandwidth Equalization with Crossover
6 Band, 1/2 Octave Bass EQ
7 Band, Octave Equalizer
Two-way 24dB/Octave Linkwitz-Riley Crossover
Programmable Frequency Match (PFM)
Subsonic Filter
Line and Speaker Level Inputs
Balanced Inputs
Input and Output Level Matching Controls
Boston Acoustic S60 Components (no grills)
Nominal Size
6-1/2" (165mm)
RMS Power Handling - 55w
Peak Power Handling - 150w
Frequency Response (±3dB)
58Hz-20kHz
Impedance - 4ohm
Sensitivity (1 watt (2.83v) at 1m) - 92dB
Mounting Depth - 2-1/2"
Prefab Dual 12" Sealed Enclosure (local pickup only)
4ch. Power Acoustik amp A600-4HP (matches mono DB series amps)
RMS Power Output: 85 Watts x 4 @ 2 Ohms
Birdged Output: 600 Watts
Signal To Noise Ratio: 97 dB
Frequency Response: 10-30,000 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: HP / LP
THD @ 4 Ohm RMS Power: 0.02 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 11.25 L x 11 W x 2.3 H
Like new LG 160W Compact DVD Shelf System with USB Port
Model: LFU850
Gamecube games: Geist, Sims Bustin' Out, NBA 2k2, Madden 2004
Computer games- Lands of Lore Guardian of Destiny, Battlefield 1942, Medieval Total War, Iwo Jima, Morrowind The Elder Scrolls III Game of The Year Edition
Nice Corona Neon Bar Sign (REAL bar neon sign)
Kenneth Cole watch
College Real Estate Books
no, but I believe it can be unlocked. It's a little scraped up, but it's normally a $400 phone. no MAJOR scrapes tho.
its a gsm phone, not cdma like verizon, therefore will not work on verizon.
and is maybe worth 250/300 max.
has a few scuffs on the surround, nothing major at all. it is a V1 dual 2
Beerdrnkr
Beerdrnkr
San Diego
skydeaner
