got a question
Its possible...I've just never had it.
If you have a cut in the rca shielding it would be alot easier to get noise also.
I say first take a set of rcas and jump straight from the HU to the amp without running them through the carpet...if the noise goes away, its the rcas.
I'd also make sure the ground was grinded down to clean metal and not on top of paint.
do the cheap stuff first
they are gonna charge you out the *** bro.
To wire directly to the speakers and have to fight with the door boots I'd charge 50 bucks a door.
The harness goes to the same wire man
no they didnt actually. they redid the wiring b/c my truck has a stock amp with sub and they rewired the the hu and amp direct in each door free of charge.
i fixed the alt noise issue by replacing the cheap rca's with high end monster 4ch rca and it sounds prefect....
now the only issue i have it once the volume gets to around 25 my amp is kicking out...
so ima have them check that out tomorrow or monday morning
no they didnt actually. they redid the wiring b/c my truck has a stock amp with sub and they rewired the the hu and amp direct in each door free of charge.i fixed the alt noise issue by replacing the cheap rca's with high end monster 4ch rca and it sounds prefect....
amp kicking out was an issue with one of the crossovers... it was somehow overloaded, but its fine now.. sounds great and 25 is loud as hell lol
deafsquadtahoe
Back from the dead
deafsquadtahoe
Atlanta
deafsquadtahoe
