good way to lock ur amp down?
Mirp
bumpin high
im drilling through the bottom of my truck and into my box so it can get took with unbolting but how can i make it so they cant just unscrew the speakers?Also how should i lock my amp down,screw it with crazy screws the best idea?
build the top of the box , put the sub in , use a flat screw with a nut on the back , have to predrill the hole to size tho since you won't be able to screw it threw the wood , use something like a ruber seal on the top end of the screw for a washer between the screw and basket , then put the nut and loctight washer on the back of the screw , put top of box on , screw it down , bam . only way to get the sub out is ripping the box apart. easiest way i know todo it. but then that can make it difficult to bolt the box down sincee you can't go through the sub hole , so you'd have to basically bolt the box down without the sub wall in.
Mirp
bumpin high
Mirp
Ohio
iamamp3pimp
