R RollinRemz05 10+ year member Senior VIP Member 278 0 Toms River, NJ Sep 6, 2006 #1 Is it good to run a ground wire from the battery all the way back to the amp? I heard from a local place I should try that to help with rpm drops. Click to read more...
OP R RollinRemz05 10+ year member Senior VIP Member 278 0 Toms River, NJ Sep 7, 2006 Thread Starter #2 up
Megalomaniac 5,000+ posts Mr.SQ 8,273 1 The Colony, TX Sep 7, 2006 #3 its a waste of wire edit: ground is ground, just make sure wherever you ground the wire to scrape all the paint from "chasis area"
helotaxi 5,000+ posts Kilroy was Here 8,961 73 South Central (New Mexico that is...) Sep 7, 2006 #4 its a waste of wire edit: ground is ground, just make sure wherever you ground the wire to scrape all the paint from "chasis area" Click to expand... Depends on the system and the car. If the system is drawing enough current the chassis could prove to be a really bad ground conductor.
Y yacob.naif 10+ year member CarAudio.com Veteran 4,218 7 White Plains, NY Sep 7, 2006 #5 its a waste of wire edit: ground is ground, just make sure wherever you ground the wire to scrape all the paint from "chasis area" Click to expand... //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Megalomaniac 5,000+ posts Mr.SQ 8,273 1 The Colony, TX Sep 7, 2006 #6 Depends on the system and the car. If the system is drawing enough current the chassis could prove to be a really bad ground conductor. Click to expand... you are right after i did some research, i retract the phrase i used about waste of wire. but most ofent or not it is unneeded to run such length of wire.
