Good budget amp 1400-1600 watts rms???
Power Acoustik BAMF 5500. Obviously the manufacturer's numbers are fictional, but they have been clamped doing well over 2k of (mostly) clean power. Plus, you can replace the front pannel with plexi and look at the pretty guts //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Good amp for the price
---------- Post added at 08:43 PM ---------- Previous post was at 08:43 PM ----------
Then the 4480
MyLows, I've seen you throw some nice deals. What you got for me, and how much? I saw one for almost $450.00!!! No way I can spend that. Also, this is going on 1 sub. Is this not too much wattage on those choices?
No disrespect intended, but I thought Power Acoustik was a brand to stay away from?
Sorry bout the mix up. XFL, if not the SQ HDS315. Also, I have a box builder waiting on me to make up my mind. But I'd like to know what you would do for one of these subs, size and price? (@MyLows)
What was the size and the tuning of the enclosure you've used? And what would you charge to build and ship? If you have that amp in stock, could we do a package deal? You can pm if you prefer.
actually the bamf/5500 is not that bad of a amp. The only way to get the rated 3200rms is to wire to .5ohm and run it at 16v. i have seen them clamped this way and they did the 3200 but protected like in like 3 seconds lol. As for daily 1 ohm, its a good 2k rms amp, not the most efficient but not to bad. Ive seen 2513 clamped at 1ohm on in realistic conditions(12v setup). so they are not just junk tho most people will say it is because its "power acoustik". I wouldnt use any of their other amps tho
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
959
810
BUDDAH
BUDDAH
Saginaw, MI
shauncox26
audiobaun
    May 19, 2024
    May 19, 2024
