good 4 channel amp?
select127
ok fellas im kinda new to the car audio scene, im trying to find a good amp to power the speakers ima be running. heres what i got:
- four dayton PA165-8 6" (8ohm & 75w RMS)
- one pair O2 OST-05 bullet tweets (4ohm & 50w RMS)
- also one pair selenium D250-X horn drivers (8ohm & 150w-200w power handling)
i dont wanna spend to much on the amp($200 or less range) so let me kno what yall recommend oh and i also plan on upgrading the daytons with eminence alpha series later on.
I assume your going to wire 1 channel to power all the 8ohm horns/speakers, but in all honesty dude your better off getting 2 component sets then try and run all of that, its mix and match ohm loads which isnt going to be easy nor good, but a good 4 channel that comes to mind is the american bass sq 480
the selenium drivers i didnt plan on runnin until they were given to me by a friend so yea i thought i might as well jus thro them in there but i can do without them. ima jus run the tweets off my h/u but what other amps do yall suggest for the daytons, ima be upgrading to the eminence alphas later on like i said if that would help. thx
select127
select127
Florida
select127
