golaith quad coil hspl15
//content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gif//content.invisioncic.com/y282845/emoticons/typing.gif.fd7c44a94b6ea7a328969e3ae0e010f7.gif i dont think you can wire it to 1 ohm.
.5 ohms or 2, 4 are the only options for that subwoofer configuration according to the search i did on it.
if theres a way, i'd be interested to learn too.
i'm in ft myers do you think my amp could handle 5ohm or just run it @2ohms they say it's made for this speaker states 1ohm not 5ohm
i think you're amp could handle it.. yes.. i wouldn't let your amp handle that for more than a few minutes though.
wire it up 2 ohms.. if you dont ahve enough power.. get another one of the same amps and put two amps on that sub.. then you could put it at 1 ohm with 2-2ohm voice coils per amplifier.
hope that helps? //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
kidroc
kidroc
fl
kidroc
michigan born
    May 14, 2026
michigan born
    May 14, 2026
