getting ready to buy items needed
blimblam
im getting ready for my install and i need to see what else i need
i already have:
headunit - panasonic cq-c8403u
comps - pg rsd 6.5
comp amp - us amps is2080
wires - knukonceptz 8gauge kit
wiring harness and replacement pocket
subs - 2 12" CVR
need:
sub amp - cadence txa 1000d
enclosure - need to let vitveet know when he can start building.
wire - knukonceptz 4 gauge kit
0 gauge for big 3. recommended length??
distro block - im not sure which one to get, but i was told that the sub amp i am getting is about 150 amps and has 1 power supply. im planning on getting this one http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=140134561853&ssPageName=STRK:MEWA:IT&ih=004
is that a good enough distro block? or do i need one that accepts at least 150 amps?
fuses
is there anything else that i need?
make sure you have 2 sets of rca's, and i have about 8 1/2 feet of elemental designs 4459 strand 1/0 wire if your interested. would be perfect for the big 3. its silver in color, PM me if your interested, and if you only plan on running 1 set of rca's PM me, i also have some nice y-adapters you could use. and there is also no use running a d-block if your gonna have two wiring kits, then you will just run two different wires, one 4 guage wire, and one 8 guage wire.
pm sent. so should i just buy a good length of 0 gauge, RCA, inline fuse holder, and speaker wire instead? that will come out to about the same as the 4gauge amp kit from knu and some 0 gauge.
blimblam
blimblam
new orleans
blimblam
