Getting No Sound!
RensoreK
I recently started having some static in my sound system and my subwoofers were distorting when I turned the volume up, so I decided to rewire my system from the ground up. Checking EVERYTHING and ensuring myself no task was "shortcut" or done weakly.
I had installed the system years ago and it worked fine. The static started so I thought it was the head unit and replaced it only to find the same problem.
I now have no sound coming to the subwoofers (or any speakers) so I decided to to check the RCAs, I ran test RCA cables from the head unit to the subwoofer amp and nothing, but if I turn the volume up high enough I get static coming from the regular speakers that are connected to its own amp.
If Im not clear in anything please let me know I tried as best as I could. Any help getting this to work is GREATLY appreciated!!
HERE IS A DIAGRAM. Hope it helps.
recheck the grounds and the speaker wire/connections. if they are all secure the only thing i can see it being would be blown amps or speakers.
Speakers are okay. They were running decently (besides static at higher volumes) before I disconnected them to restart checking everything from scratch. I replaced the RCA cables for the subwoofer amp to make sure the RCAs weren't bad. All grounds were upgraded to lower gauges and checked for corrosion and I wire brushed all connections just in case.
I also re-checked to make sure no fuses were blown on either amp. They both worked fine last week so It must be a wiring problem I'm assuming...
God do I like this forums. I was having the same problem and I wasn't thinking straight. When to the amp check if the fuse were bad or something push on them and found they weren't all the way in. Fixed my problem.
RensoreK
RensoreK
Orlando, FL
MrChow
