Germanium tweeter config
WiCKeD 5.9L
The tweeters are just a shade too bassy and I want to bump up the dB a little. What setting would you recommend if the tweeters are installed above the dash?
1. Direct Loud - Recommend for kick panel operations in floor space. Tweeter is unattenuated.2. Linear Balanced (Default) - Recommended for lower door, floor space or rear install
3. Middle Optimum - Recommended for instrument panel with strong widnshield reflection. Gradient freq response was designed in such a way that the middle- to high-tone drop continually by octave
4. Reference Soft - Recommended for instrument panel with strong widnshield reflection. Gradient freq response was designed in such a way that the middle- to high-tone drop continually by 2 dB per octave
I think 1 = ???, 2 = 0dB, 3 = -1 dB, 4 = -2 dB
There is another option to change the cut-off frequency:
Jumper J1 (Low Pass Woofer): If the distance between and/or angles of the woofer and tweeter cause an undesirable increase in the pressure level, changing the cut-off frequency of the woofers may solve or improve the problem.
In position A: default cut-off frequency (approx 2.200Hz)
In position B: default cut-off frequency (approx 2.600Hz)
Jumper J2 (High Pass Tweeter): If the distance between and/or angles of the woofer and tweeter cause an undesirable increase in the pressure level, changing the cut-off frequency of the woofers may solve or improve the problem.
Would I want to raise the cutoff for both to 2.600Hz? Not sure why there is a separate setting for the woofer/tweeter.
Yup, I did that, set them to setting 1 and reversed the polarity (per the manual). They sound awesome now!
I also tried setting 4 to contrast and they sounded like they were underwater. I may bump them back down to 2 to keep them from breaking up at ultra high peaks. The cutoff frequency was the biggest improvement.
Man, I was already melting from the midbass these put out and now am extremely happy with the whole package! Overall sound hits all ranges.
WiCKeD 5.9L
WiCKeD 5.9L
San Clemente, CA
slick rick
