General Motors Aftermarket HU replacement question
aea151
23
here
Heres my situation:
I have a Suburban that has a seperate factory CD player from the factory HU. I want to replace the HU but also want to retain use of the factory CD player (maybe attach an adapter from the aftermarket HU to the factory CD player).
Is this possible? If so, what HU would be reccomended and how?
Thanks in advance.
hit up a company called soundgate, you'll be needing a few things from there. this has been done before. you can get away with not having the factory HU at all, ask me how i know.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
859
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
883
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
Run man... Run!! 💩 💩 👀 👀 :LOL:
aea151
aea151
here
aea151
