gains up, sub not pounding
Ok so now that i know ~83 volts is where clipping light comes on. How the hell (wired at 4 ohms) do i get it to the 89-93 v range without clipping light going off.
I'd personally wire to 1 ohm and set the gains with a dmm. Id rather have a 4k watt amp @ 1ohm, and only using 2k watts of the 4k than to have a 2000@4ohm trying to get 2k. But that's just me.
Have you tried tweaking the other settings you have? I'm not sure about your HU but on my Pioneer there are a bunch of settings: Bass Boost, Sub Freq. Boost/Gain, Loudness setting, 3-Band EQ, Parametric EQ Adjustments, SLA, Sound Retreiver etc...
All these will ultimately come into play when determining how much power the HU is outputting to the subs... try dicking around with your settings and then set your gains accordingly.
Thanks for the help avs20, really appreciate it.
first time doing this myself...gotta start somewhere.
oh and thanks for the help rashaddd, to bad you didn't join the site 5 years ago so you could help EVEN MORE people with your comments.
dennis09x
dennis09x
canada
microhaxo
BP1Fanatic
BP1Fanatic
