Fuzes always blow!?
FeRReT
I have my amp and 2 subs hooke dup correctly, like i have for the past 3 months... I just took it out once to update my homemade box. Now, whenever i either connect the ground and power wire or the fuzes they blow instantly! Everything is hooked up the same way. WHATS THE PROBLEM!????
Originally posted by FeRReT I have my amp and 2 subs hooke dup correctly, like i have for the past 3 months... I just took it out once to update my homemade box. Now, whenever i either connect the ground and power wire or the fuzes they blow instantly! Everything is hooked up the same way. WHATS THE PROBLEM!????
they blow with the amp off???? did you hook it up backwards
Did you discocnect the negative terminal on the battery if not this will blow your fuses.
Some circuits do have a constant draw, if there is a load that uses it, like radio settings, but it's not a battery pushing out that voltage...
796
That’s barely rarified air in home audio. Those guys use interconnects that cost more than my system, lol. I’ve heard some of the lower end of...
21
4K
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
FeRReT
FeRReT
NOrthfield MN
chris229
    May 18, 2024
    May 18, 2024
