I have a Fusion NV Series 15" Sub, a Fusion Powerplant 2000 watt Amp , and a
15" ported speaker box that I am selling...
I want $450 for everything plus shipping. Make offer.
I paid $700 for everything. Still have my receipt. Still have all original boxes.
Ive just had them sitting in my closet.
I bought this system for my IS300. The speakerbox will not fit into my trunk.
It was only used in my truck for a month. Less than 30 hours of play.
Im getting sponsored for SEMA with my is300 so I decided to sale the equiptment.
In case you arent familiar with Fusion. PAS magazine did a write up/test report a sub and amp of theirs in the Dec 2007 issue.
Ill post some pics by this weekend. Or you can email me at ehende22@aol.com.. or PM me if interested.
Sub:
Power Rating: 2500 Watts (Max)
Voice Coil: 3" TIL Dual Voice Coil
Impedance: Dual 2 Ohm
Magnet Structure: 308 oz Triple Stacked
Amp:
Monoblock Power Plant Series Amplifier
Superior Thermal Conductivity : PowerPlant amplifiers feature superior thermal conductivity ensuring heat dissipates efficiently
Rugged Amplifier Case : Single piece extrusion with seamlessly matched die-cast end caps which protects connectors and internal components
Over-sized Mounting Feet : The oversized mounting feet with their recessed holes provide secure and discreet fastening points.
Over-Sized Power Connection : Enlarged contact surfaces for high current connectivity
Stage 2 System Management Panel : Multi-function management panel enables you to refine the characteristics of the signal to suit your audio preferences.
Multiple Fuse Protection : Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Linked Power Ratings @14.4VDC
1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 2000 Watts
Max Current: 100A
Full Rated Power Distortion (Max) 1kHz: 0.45%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 12 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 25A x 4
Sub:
Amp:
Max Current: 100A
