Bandwidth 10Hz – 250kHz
Signal to Noise >95dB
Fuse Rating 2 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 12dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz – 50Hz
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 57.5mm L 360mm H 220mm
14.4 Volt Power Output Specifications
325 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
550 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
700 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
Linked Power Ratings @ 14.4VDC
1150 Watts RMS Linked @ 4 Ohms
1550 Watts RMS Linked @ 2 Ohms
