Sold Fs: Hifonics Colossus ll
i3abyjay25
Get F'n Loud
Hifonics XX-Colossus II
New 2006 Model
MSRP: $2,995.00
Hifonics amps have always been a powerhouse. When they first came out there were only 4 companies that made amps(Linear power and Rockford Fosgate were 2 of them and no slouches at that), but Hifonics was then more powerful and still is. The Colossus is no exception. 3,200 watts into 2ohm and more if you put enough juice to the amp. So if you want to bump go with at least 400 watts, but if you want to pound the sound the Colossus is the ticket. just make sure you have subs that can take the power.
* “Hybrid” 2-Channel/Mono Block Super D-Class Amplifier
* 2/1 Channel Operation
* Ultra-D Class Amplifier Design
* RMS Power Ratings:
o 600 watts x 2 chan. @ 4 Ohms
o 1100 watts x 2 chan. @ 2 Ohms
o 1600 watts x 2 chan. @ 1 Ohm
o 2000 watts x 1 chan. @ 4 Ohms
o 3200 watts x 1 chan. @ 2 Ohms
* Illuminated Hifonics Badge
* Removable Endcaps
* 0° - 180º Phase Shift
* Variable Subsonic Filter: 15 - 35 Hz
* Variable Low Pass Filter: 35 - 250 Hz
* Bass Boost: 0 - 18 dB
* Bass Remote with Blue LED
* Complimentary / Balanced High-Speed MOSFET Output Devices
* PWM MOSFET EXVP (Exponential Vari-Power Supply)
* SPC Twin Turbo-Torroids with Simpatico Coil Design
* Power and Protection LEDs
* Gold Plated RCA Outputs
* Gold Plated RCA Line Inputs
* XLR Mini DIN Socket for Balance Line Input
* Variable input level: 200mV - 9V
* 2 Gauge Gold Power Connectors
* External Fuse Required (300A Reconnended)
* Power From The Gods Included
* Dimensions: 28" L x 11.2" W x 2.6" H
* 1-year Sonic Electronix warranty
Amplifier Specifications:
* Number of Channels 2
* RMS Power (4 ohms) 600 watts x 2 chan.
* RMS Power (2 ohms) 1100 watts x 2 chan.
* RMS Power (1 ohm) 1600 watts x 2 chan.
* Bridged RMS Power 3200 watts x 1 chan.
* Peak Power Output 6400 watts approx.
* Min. Impedance Unbridged 1 ohm
* Min. Impedance Bridged 2 ohms
* THD @ Rated RMS Power 0.1%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes - 1 Pair
* Built-in Crossover LP (35 - 250 Hz), Subsonic (15 - 35 Hz)
* High-Pass Crossover N/A
* Low-Pass Crossover N/A
* Subsonic Filter N/A
* Signal-to-Noise Ratio 95 dB
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote N/A
* Fan Cooled No
* Fuse Rating 300A External
heres a link of 1 from Ebayhttp://cgi.ebay.com/Hifonics-XX-Colossus-II-1-2-ch-3200-Watts_W0QQitemZ5862643527QQcategoryZ4950QQrdZ1QQcmdZViewItem
800$ shipped
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
i3abyjay25
