fuses parallel
i cant find a 100 amp fuse all i can get my hands on is two 50s and a electron said i could run two 50amp fuses parallel to get 100. is this possible
some of the fuse-limited guys will chime in maybe.
What type of fuse? ANL? surely not.
edit. parallel fusing is possible, but 2x50A I don't think is a straight 100A due to tolerances, etc. I could be wrong.
Upon further review, and much googling, you can parallel fuses to increase current capacity. However, 2 50A fuses is not equal to a 100A capacity.
You must, however, take into account a derating factor of about 80% - 90%.
This means that if you parallel two 50A fuses, the effective current rating is raised to only ~85A
Two 60A fuses in parallel will do what you're looking for (Effective rating of ~102A)
well after some one saying you can do it i got piss i just said *uck it and went to all the local hardware stores and found a 100 amp fuse i can use. got it all wire up thx you all for you help and as noted i will never use welding wire for big three again to dam stiff
Exactly why I sold mine and got hyperflex. Too **** hard to run welding wire.
1 fuse certainly makes the equation much more simple //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bopo668
JerryRig
bopo668
tex
bopo668
AJ (ACE)
    Jun 28, 2026
