Ded
hey guys im new here and am in the process of getting a system built however i have a question. I will be doing the big 3 on my car with 0 gauge wire and be running the wire to my amps. i will be running 2 amps, 1 mono and a 4 channel for my components. i was wondering if i used a power distribution block to run power to both amps if i should get a fused one or a non fused one because it will most likely be 0 gauge power being sent to 4 or 2 gauge wire through the block to the amps. i will be fusing the 0 gauge to the back about 10 inches from battery and the battery to alternator as well.
NVX XFDBU2 Fused Distribution Block 0/1 Ga Input + 4/8 Ga Outputs
this is the fused block i was thinking about getting. also if i am right about using a fused block what size fuse would i use with a 1400rms at 2 ohms mono block amp for my subs and 75rms x 4 for my 4 channel? both amps cea-2006 compliant if that matters?
