Funky Pups
Warning!
THE FOLLOWING PICTURES ARE NOT YET RATED:
so how many wats should i run to each and how much cube air space per sub? (i'm gonna get some)
Anyone got a seriouse answer? Or is all this a gag? Come on now somebody giva me a real answer.
The size of the box you use is irrelevant, pups work in every box size and configuration that could ever exist and that ever has. However if you put too many together you may cause a rift in the space time continuum
What the Hell?????
The Mavin Uni-Z 4/8jp combines the best features into one Universal Speaker that performs just as well at 3, 4, 8 or 12 Ohms.
How? You might ask. Simple the Uni-Z-4/8jp is a 4 or 8 ohm speaker in one package. Hook-up is simple too, if you need 4 ohms, hook up the 4 ohm side, if you want 8 ohms, then plug into the 8 ohm side, it is two speakers in one.
If you want to handle more power connect the 4 and 8 ohm connections to getther for 3 ohms, the speaker will take 700 Watts RMS and 1400 watts peak...
KB777
KB777
home
nineball
    May 13, 2026
