SOLD funkinaudio mf 800 amp
plumbcrazy
N.C
ok i got a funkin audio mf 800 amp it does 800 rms at 4 ohm 1600rms at 2ohm and 2400rms at 1ohm it takes 1/0 direct its just way to much power for my subs i would recommend a extra battery to power this amp i have some refs of on roe americanbassguy1 and ebay slammed_57 im starting this off at 200 obo or would trade for some lower wattage amps
it looks pretty bent up... What happen to it? Why is there a hole drilled into the side of it? How much lower wattage amps u looking for
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
698
Looks Like I just saw a new 5 ch. amp on the CT Sounds Site as I was browsing today. Looks like the Sub Ch is 1 ohm stable to 400 watts. Might be...
  • Locked
You must post pictures with username and date (on a piece of paper, a digital version will not be suffecient) unless you have sold to at least 10...
plumbcrazy
plumbcrazy
N.C
plumbcrazy
    May 18, 2024
    May 18, 2024
