Fully loaded BTL specs posted
From Scott @ the Fi forum:
Here are the specs for the current fully loaded BTLs (3rd magnet, high Xmax coil, and full cooling).
BTL12
D1 D2
Dcr .7 Ohms 1.4 Ohms
Fs 37.9 Hz 36.4 Hz
Qms 5.15 5.36
Qes .27 .25
Qts .25 .24
Cms 8.2uM/N 8.2 uM/N
Mms 216 g 234 g
Vas 26.4 l 26.4 l
Sd 480 cm^2 480 cm^2
Spl 89.1 88.7
Bl 16.4 24.6
BTL15
D1 D2
Fs 35.7 Hz 34.1 Hz
Qms 5.71 5.86
Qes .30 .28
Qts .29 .27
Cms 7.6uM/N 7.6 uM/N
Mms 261 g 285 g
Vas 70.1 l 70.1 l
Sd 810 cm^2 810 cm^2
Spl 92.0 91.8
Bl 16.4 24.6
BTl18
D1 D2
Fs 31.6 Hz 30.3 Hz
Qms 6.28 6.53
Qes .33 .31
Qts .31 .30
Cms 7.8 uM/N 7.8 uM/N
Mms 324 g 351 g
Vas 160.7 l 160.7 l
Sd 1210cm^2 1210 cm^2
Spl 93.7 93.5
Bl 16.4 24.6
Note: These will change with the addition or subtraction of different options from the fully loaded versions.
Just an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
why dont yall try reading fi's website
"Need incredible Xmax to feed your 160dB at 20Hz obsession? Add a third magnet and our extended length coils (26mm of Xmax)."
durrrrrrr
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif thats where i got it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
xluben
