Here we go again...
Dont forget to check the O2 sensor and MAF as they tell the engine JUST how much fuel is needed to maintain a proper A/F ratio,
also if you doing the plugs you might want to also upgrade the wires and coil (MSD is a good one)
There's way more to ignition systems than MSD.
Might be a good idea, get a bosch one
also the plugs would be good too, I got the P4s and I noticed a little difference at idle and acceleration, I probably wouldn't of gotten them except I got a killer deal on
ebay on em'
Bosch plugs are SHIT. Get what is recommended for your car. There are very few engines in cars built in the last 10 years, that you can improve by changing plugs. Don't you think if simply changing a spark plug would yield better mileage, the manufacturer would have done it? And it's been lab proven, that the only style of multi-electrode spark plug that works is a V style, like a Splitfire. The only difference being, that the spark acr'd between the upper electrodes, rather than between the upper and coil electrodes, moving it slightly further into the combustion chamber. For a spark plug to ACTUALLY provide the 4 sparks that the Bosch +4s claim, it would need 4 coil electrodes, and 4 sparks. On Bosch +4s, you don't get 4 sparks or 4x the spark, you just 4 places for that same old spark to jump to.
hmm is there only 1 02( oxygen sensor ) on the car?
Most likely 2, and often as many as 4-6.
hmm i c how much MPG's do ppl usually gain after getting new 02 sensor and MAF
You won't see a gain, you'll see a reduction in loss. And unless the MAF is REALLY bad, you're better of leaving it alone. And if it was bad enough to need cleaning, your car would lurch, jump, idle poorly, and generally drive like shit. If it's idling and accelerating smooth, leave you MAF alone. It's fragile, and expensive.
Depending on how F'ed it is and your engine I would say 5+mpg for the O2 sensoralso you can test the O2 sensor with a accurate multimeter, or just get a new one for like 50bucks
clogged MAF can cause the same problem you can clean your MAF if you want to save money (as MAFs arent cheap here is how)
use ELECTRICAL CONTACT CLEANER. This is the only thing you should use to clean your MAF. Only ELECTRICAL CONTACT CLEANER. No windex, no carb cleaner, no brake cleaner, no rubbing alcohol, and no Q-Tips.
Step 1: Open the hood and locate your air box. If you can't find it...please stop right now and have a friend clean your MAF for you.
Step 2: Open the airbox and move the assembly up to give you room to work.
Step 3: Locate the plug on the bottom and move the grommet down to give you room. See picture.
Step 4: Take the flathead screwdriver and pop the four tabs holding the assembly in.
Step 5: Reach in and disconnect the wiring harness from the MAF. Don't rip the wires or anything!
Step 6: Remove the assembly. Locate the MAF and remove the two screws holding it in.
Step 7: Spray the living daylights out of the wires. Do NOT touch them. ABOSOLUTELY DO NOT TOUCH THEM. Those wires are very small and delicate. If you break one of them....it's a $150 mistake.
Step 8: The installation is the reversal.
Do this once every 6 months and your MAF will continue to be clean and your performance won't suffer.
ALSO dont forget about your plugs and wires
Cleaning your MAF is a huge risk, unless is NEEDS to be cleaned.
An O2 sensor would have to be absolutely obliterated to cost you 5+ mpg, and to test it with a multimeter, you would also need a torch, and something to hold it up for you. Testing it this way often destroys it. It's designed to withstand certain temperatures, and it changes the amount of voltage it puts out depending on it's temperature. You have to heat it up and check to see what the amount of resistance is at certain temperatures. Usually, as soon as it cools down, even if it tested good, it is no longer worth a shit. Getting up to operating temperature via a gradual increase in air temperature is what it's designed for, not being heated very quickly by an open flame that is twice the operating temperature. Keep in mind, the element inside of it, it ceramic, so be very careful not to drop or jolt them either.
SuperchargedRS, you're not allowed to give car advice any more. Shut up.
