fuel additives
Are you talking about power adders?
Fuel additives you buy at walmart ARNT power adders
THIS is a power adder
when is the last time you replaced your O2 sensor and plugs?
im not sure when the last time was it might of been at 60000 when chevy did there checkup . right now im sitting at close to 90000
Depending on how F'ed it is and your engine I would say 5+mpg for the O2 sensor
also you can test the O2 sensor with a accurate multimeter, or just get a new one for like 50bucks
clogged MAF can cause the same problem you can clean your MAF if you want to save money (as MAFs arent cheap here is how)
use ELECTRICAL CONTACT CLEANER. This is the only thing you should use to clean your MAF. Only ELECTRICAL CONTACT CLEANER. No windex, no carb cleaner, no brake cleaner, no rubbing alcohol, and no Q-Tips.
Step 1: Open the hood and locate your air box. If you can't find it...please stop right now and have a friend clean your MAF for you.
Step 2: Open the airbox and move the assembly up to give you room to work.
Step 3: Locate the plug on the bottom and move the grommet down to give you room. See picture.
Step 4: Take the flathead screwdriver and pop the four tabs holding the assembly in.
Step 5: Reach in and disconnect the wiring harness from the MAF. Don't rip the wires or anything!
Step 6: Remove the assembly. Locate the MAF and remove the two screws holding it in.
Step 7: Spray the living daylights out of the wires. Do NOT touch them. ABOSOLUTELY DO NOT TOUCH THEM. Those wires are very small and delicate. If you break one of them....it's a $150 mistake.
Step 8: The installation is the reversal.
Do this once every 6 months and your MAF will continue to be clean and your performance won't suffer.
ALSO dont forget about your plugs and wires
hmmm i think i might go clean my MAF too. I've read you'll get better performance out of copper sparkplugs but they don't last nearly as long as platinum. That's a 6 cylinder right? You might have 2 02 sensors, that could be expensive to replace. I know my ford 3.8 has 2 after the cats.
amoffitt
amoffitt
Dallas Tx
whiteZ714x4
