fuel additives
hmm i might have to do that. you said it was kind of expensive. how much does it go for?
i never bought it. i just use some from the company since they get mass quantities. i did see some at checker though and i thought i remembered around 30$. it was behind the counter seperate from all the other additives.
dont boost your octane! what is your compression ratio? putting higher then needed octane will just waste money
If you want better fuel economy do a good tune up, nice plugs maybe thicker wires (ignition system overhaul/upgrade), you could put a better flowing exhaust system on, CORRECT tire pressure, new O2 sensor (that can really help) check your MAF sensor, better airfliter/induction system.
Those fuel additives are commonly used as a crutch for shady maintaince.
hmm i put it in there every now and then i just had the fuel system cleaned. i have a magnaflow cat converter and a aftermarket exhaust. and i have a air intake. i will probably look into changing spark plugs.
amoffitt
amoffitt
Dallas Tx
whiteZ714x4
