FT: 2 10" atomic ap/spls
JL Audio
ThugStep
Rating: 94.4%
17 1 0
These are posted on realm as well.
I fixed the dent in the dustcap also.. lol.
pics:
Looking for 6.5 component sets, 6.5 coaxials, an amp( no certain one in particular), a small sub setup for a single cab s10.
Feel free to post all offers though, including $.
Bump for Justin.
Very trustworthy & good seller.
I'll trade you my phone for both. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dual 1 ohm, 1000w rms, very underrated though. Headshok an atomic dealer had his two hooked up to a 5000.1 daily. mounting depth is also right at what you're looking for.
atomics says:
* APSPL 10, Available in DVC 0.7, 1.0, 1.4 and 2.0 ohms
* Rigid Die cast aluminum basket.
* Organic long fiber non-pressed cone body for accurate tight bass.
* Curvilinear Kevlar reinforced cone body .
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity.
* Butyl rubber surround heavy duty and forever lasting.
* Compressed mounting ring gasket.
*Vented coil for extra heat dissipation.
* 2-1/2 inch high temp aluminum voice coil.
* Extended, machined cut one piece back plate.
* Powerful 1 inch thick 90 oz high energy magnet.
* 2-1/2 inch long excursion motor structure.
*Reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
*Integrated heavy duty lead wire on spider prevent short circuit and melt down.
I have a digital audio monoblock dab1800x. here's the specs? also do these do well in ported boxes?
800 watts x 1@ 4 ohms mono
1600 watts x 1@ 2 ohms mono
as far as ported:).. very.
Each sub is geared toward competitors competing in stock vehicles in USACi. NSPL, MECA, EMMA, Db Drag Street A, B, C & Max. The Apocalypse series is an excellent choice for a competitor on a smaller budget.
and no go on the amp for now.. wanna see more offers first.
JL Audio
ThugStep
JL Audio
KY
JL Audio
