Sold FS: Zapco Z150S2 Amp
pilyin
Nice older Zapco two channel amp here. Decent shape. I'd say about a 5/10 cosmetically but 10/10 functionality. The lettering on one side is worn off, but it just had the gain knob markings and said the button was mono, stereo. Notice in the last picture the plastic base is slightly sagging. The amp works perfectly though.
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 20A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .85A
Dimensions 11.625"x6"x2.25"
$65 shipped
pilyin
pilyin
Bellingham, WA
pilyin
michigan born
    May 14, 2026
michigan born
    May 14, 2026
