I am out of the car audio completely and need to sell the rest of my stuff.
I have a bunch of random rca cables, 4 gauge power wire, fuses, and fuse holders, along with an AIMS 800 watt power inverter.
Cables, fuses, and fuse holders:
20ft rca cable with amp turn on- KnuKonceptz, Klarity Konnectz
15-20ft rca cable- KnuKonceptz, Krystal Kables Triple shield twister pair
17ft power cable 4gauge, Stinger EXPERT ultra flexible, high amperage
17ft power cable 4gauge Kolossus kable by KnuKonceptz
I then have a few random fuses 2-80A, 1-60A, 1-20A and 120A fuses in KnuKonceptz cases, everything is setup so that you can just attach it to the battery, they all have power connectors at the tips.
fuse holders: KonFUSED 2 Way Distribution System, with fuses installed.
In-Line Waterproof ANL Fuse Holder w/ Fuse (FH-20), and a smaller fuse holder made by KnuKonceptz.
Every wire, fuse, and fuse holder is from KnuKonceptz, except for the stringer power cable.
I have all the cable an install would need for a system with multiple amps, needing multiple runs from the battery and multiple grounds.
i also have about 20ft of tsunami speaker wire- 16 gauge
There is slight wear and tear on the wire, some browning from the engine compartment, however there are no slices in the wires and everything is fully functional. I will only sell all the wire, fuses, etc together
Price shipped= Best Offer + $15 shipping
Lastly i have an 800 watt Aims power inverter.
6.66 amps continuous power
modified sine wave
2000 watt peak output sure
Was used to power a mac mini.
Will take pictures if anyone is interested in it.
modified sine wave
