I have a used US Amps USA-4300x for sale. This amp came out of my truck, and its the first time I've taken it out since my install was completed in Oct 2004 (see sig). This was one of the last amps US Amps made before the move from Florida to California.
The only thing you will not get is the 1/8" acrylic back that came with the amp, since it had to be used as part of the amp shroud. There is nothing wrong with the amp, and scratching is very minimal. I'm asking $450 shipped to the 48 continental states. Paypal is NisAznMonk@aol.com
* Four Channel Class AB Amplifier
* Total Power Output: 360 Watts RMS
* THD at Rated Power:
* Stereo Separation: >98dB
* Signal/Noise Ratio: 102dBA
* Frequency Response: 5Hz-50KHz
* Fuse Rating: 60 Amps
* Weight: 3.63kg / 8.00lb
* Variable 24dB Two-Way Active Crossover
* Remote Bass Gain
* Two Ohm Stable
* 75 Watts x 4 into 4 Ohms
* 80 Watts x 4 into 3 Ohms
* 90 Watts x 4 into 2 Ohms
* 180 Watts x 2 Bridged into 4 Ohms
* Remote Bass Gain
* Two Ohm Stable
