*mint* US amps TU-4360 Tube 4 channel amp. Excelent SQ amp. SOLD
TU-4360
Four Channel Class A Amplifier
Direct Tube Input
Oversized MOSFET Power Supply
Total Power Output: 360 Watts RMS
THD at Rated Power:
Signal/Noise Ratio: >100dBA
Frequency Response: 15Hz-50KHz +/-0dB
Fuse Rating: 40 Amps
Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
368mm / 14.50in Long
Weight: 3.63kg / 8.00lb
Two Ohm Stable
75 Watts x 4 into 4 Ohms
90 Watts x 4 into 2 Ohms
Audiocontrol EPIC-150 Comes exactly how it would if it was BNIB. All mounting, manuals, mechanically 10/10 Cosmetic 9.75/10 $140 shipped
I have many refs on this forum and others. DBdom, flipX99, dbman150, teamPSI, and others I cant think of at the moment.
TU-4360
Direct Tube Input
THD at Rated Power:
62mm / 2.44in High
229mm / 9.0in Wide
Two Ohm Stable
