FS: US AMPS MD3D - $375 OBO
If you have an offer MAKE IT... I will not answer a PM that says "What is the lowest you will take?" NO TRADES!!!!!
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
* 650W x 1 @ 4O mono
1200W x 1 @ 2O mono
2000W x 1 @ 1O mono
* Total Harmonic Distortion: 0.03
* Frequency Response: 20~250
* Power Band Width (Frequency Response): 20~500 Hz
* Crossover Frequency: 40~250 Hz - 15~40 dB
* Damping Factor: 100
* Dimensions: 2.5 x 10.5 x 21.75 Inches
* Fuse Rating: 30A x 3
* Power Voltage Range: 12~16V
* High efficiency Class D design(1D/2D/3D)
* Output stages utilize high-current MOSFET devices
* High speed, audio-grade components in all low-level stages
* Active Constant Current Bias Tracking Circuit
* Platinum-plated RCA inputs and connectors
* Wide range of sensitivity accepts signal from any head unit
* 24dB/octave Subsonic Crossover
* 24dB/octave Lowpass Crossover
* True Line Output
* Auto Bridge feature
* Short Circuit Protection
1200W x 1 @ 2O mono
2000W x 1 @ 1O mono
* True Line Output
