Sold FS: US Amps MD1D - $200 OBO
sundownz
Pro Seller
Supporting Vendor
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
* 1200 Watts RMS @ 1 Ohm
* 750 WATTS rms @ 2 ohms
* Bridgeable with multiple MD-1D amps
* Efficiency:
o 86 % @ 4 ohms
o 84% @ 2 ohm
o 76% @1 ohm
* Built-In Electronic Crossover, Selectable 24dB per octave butterworth (adjustable 40-250 hz)
* 24dB Subsonic Filter 15-40 HZ
* Bass EQ 30 dB @ 45 HZ (This bass EQ on this amp has a much bigger punch than any other amp we have ever carried)
* Low level RCA input
* Block power connector
* requires 4 gauge power and ground wires
* 8 - 18 gauge speaker wire inputs
* Aluminum heatsink
* Screw terminal speaker connectors
* Convention cooling system
* Digital Class D efficient power supply
* Frequency Response: 20 Hz - 250 Hz
* Free bass remote included!
* 3 x 30A fuses!
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
