Sold FS: US Amps AX-1500DE (1500W @ 1ohm)
BreakingBad
Banned
US Amps AX-1500DE
Details:
NOTICE: Amp was damaged in car accident. RCA cables were torn out of amp, destroying the RCA inputs of the amp. I don't have the time or money to deal with getting it repaired, or the electrical knowledge of opening up the amp and repairing the rca ports (only thing that was damaged). Other 1500w amps are going for 250-300 (sundowns, etc.) but being this is a little more expensive (about $400 more expensive), i'm willing to let this go for $200 + shipping.
Amp details:
The AX Series of amplifiers have an almost indestructible power supply to provide max power while maintaining the utmost sound quality. They are under-rated, which means they'll pump out more actual sound power than the RMS power-rating indicates. These amps use high mass, hand-wound toroid cores that pass massive amounts of current, allowing very serious drivers to be used with them. Expect great sound quality from these amps, with very low THD (Total Harmonic Distortion) and a very high dampening factor.
This DE Class amplifier utilizes an analog version of the D Class amplifier, which means it's better than a standard class D amp in these ways:
* More Efficient
* Larger frequency response
* Faster response
* 3 times the damping factor
* More RMS power
AX-1500DE (AX.1500DE/AX1500DE) Features:
* 90% Efficiency at clipping
* Master / slave Input Drive capable
* Dual Power Toroids
* Variable Low-Pass (LP) Crossover
* Subsonic Filter
* Non-computerized SAT
* S/N >86 dB
* Damping Factor >250
AX-1500DE (AX.1500DE/AX1500DE) Specifications:
* 300Wx1 @ 8ohms (Watts RMS)
* 500Wx1 @ 4ohms (Watts RMS)
* 900Wx1 @ 2ohms (Watts RMS)
* 1500Wx1 @ 1ohm (Watts RMS)
Asking Price: $200 + shipping to your zip (UPS) (PAYPAL ONLY)
Refs in sig, ebay user id "so4d"
Pic:
ttt
AFA other damage to the amp...none. only RCA's. the accident moved the box which yanked on the rca cords. the system played fine until the rca ports eventually just fell out. nothing else is damaged, i can promise that.
BreakingBad
Banned
BreakingBad
pittsburgh
BreakingBad
