Sold Fs- Us Acoustic Zed Audio 6 Channel
energizedsbs
ok guy up for sale i have a us acoustic build by zed audio amp... this is a 6 channel that is in 9.5/10 in looks and 10/10 functionality... i will take trades so tell me what you got and i'll think about it... and also you can go active on fronts with this amp with no added crossovers or anything... ch 1&2 go from 45 to 5k and ch 3&4 45 to 5 k and 3&4 has another one that goes from 45 2.3 k...here are the specs @ 12.9 volts:yumyum:
$200 shipped and insured
have refs on carsound and performance
USA6300
OUTPUT POWER
Per channel @ 4 Ohms
@ 12.9v input 50Wx4CH and
65Wx2CH
Per channel @ 2 Ohms
@ 12.9v input 75Wx4CH and
80Wx2CH
Bridged Mono @ 4 Ohms
@ 12.9v input CH 5 & 6 ONLY
150Wx2 into 1 Ohm
or 300Wx1 into 2 Ohms
TOTAL HARMONIC DISTORTION LESS THAN 0.01%
NOISE below rated output 104 dB
SLEW RATE 20 volts/microsecond
PHASE RESPONSE Lagging 12 Degrees at 20kHz
INPUT SENSITIVITY 100 mV - 8 Volt
INPUT IMPEDANCE 22 Kilo Ohm
DAMPING FACTOR Greater than 100
PROTECTION:
Reverse Polarity Yes
Thermal Yes
Short Circuit Yes
D.C. Yes
IDLE CURRENT 1.0A
FUSE RATING 25Ax2
SIZE Length 15.3 (390)
inches (mm) Width 8.2 (209)
Height 1.9 (47.3)
WEIGHT lbs. (kg) 9.0 (4.1)
energizedsbs
energizedsbs
tarpon springs
energizedsbs
