[FS] Taramps DSP3k with Warranty
SounDrive
Pro Seller
www.soundrive.audio
Taramps DSP3000 1 ohm version
Nearly brand new. Has roughly ~9.5 months of warranty remaining.
Heavily upgraded new version of the HD3000. Better heat sink, power supply, vibration resistance, and best of all it has a feature to prevent clipping so you don't have to worry about harming your equipment. Also has adjustable bass boost with frequency adjustment, so essentially 1 band of EQ. And phase adjustment. Flat response from 8-20kHz. Also features a voltage meter on the heatsink.
Remote clipping light will be included.
This was used in my personal vehicle (I am a taramp's dealer) and I'm moving up to a larger amp.
$450 shipped firm
$430 picked up in Lebanon, Murfreesboro, or Knoxville TN
Included in price
Would thus run fine at .7? I know they,don't like wiring under rated ohms.
Depends. .7 impedance I wouldn't recommend - for example 3 D1 subs wired together. But .7 DCR is a different story, lots of 1 ohm coils will read .7 on a multimeter but their Zmin (nominal impedance) is still 1 ohm. Fi D1 coils almost always read .7
I have 2 tc sounds tc-2000 12's. They are d4 but each coil is actually 3.1-3.2 so more like .75-.8 ohm final load.
It would be fine in that case; impedance and dc resistance aren't always the exact same so you're still wired to 1 ohm. People run the 2 ohm amps at 1.4 no problem because that's DC resistance and not the actual impedance the amp sees.
Thanks man that's what I wanted to hear.
SounDrive
Pro Seller
www.soundrive.audio
SounDrive
Lebanon, TN
SounDrive
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
