SOLD FS/T RD Audio D9 5400w
CL1CKCLACK
CarAudio.com Boss
RD Audio D9 Amp
Item Description/Condition:
The Amp is in pristine condition. there isn't a single flaw on it, and it has never been repaired nor ran on low voltage 10/10 cosmetically, 10/10 mechanically
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
800+Ship and "Handling" Fees... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Trade For A 2k-3k Amp+Cash
Will Ship Anywhere in the world, at owners cost
A Link would be very helpful. Id be interested in taking a look at some gear
52
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
222
CL1CKCLACK
CarAudio.com Boss
CL1CKCLACK
Land Of The Hicks...
Ge_off_me
