I really hate to part with this but need money so... It has a custom Machined aluminum modular frame, Custom Machined Neo underhung motor, foam surround, carbon fiber dustcap, 3" Voice coil, Large spider, DVC. It’s not the most versatile sub, but it sounds amazingly good seeing as it models up for a really peaky SPL type enclosure. I've tested it in a 65L@43hz with a 6" port(down to 25L models similarly only ~2db less on the peak, but would then need a higher tune or a passive rad) , and been feeding it 2500rms, for a several min at a time, I stop when the motor gets hot. I built it myself, it is an underhung neo motor, with an Adire Tumult VC, 25mm Xmax, 30ish Xmech, it works but it turned out to have a very high Qts and low efficiency, BL~10, $500 OBO
http://www.caraudio.com/forum/attachments/subwoofers/26515488d1262308967-post-your-one-off-rare-custom-subs-img_3457small-jpg
http://www.caraudio.com/forum/attachments/subwoofers/26515489d1262309032-post-your-one-off-rare-custom-subs-img_3443small-jpg
http://www.caraudio.com/forum/attachments/subwoofers/26515490d1262309043-post-your-one-off-rare-custom-subs-img_3450small-jpg
