FS: Stinger SPV70
MiX
spv70
Item(s) Description/Condition: used. resting at 12.8
90 plus shipping
Shipping and Miscellaneous Item Information: package is 60 pounds from 66609
Internal resistance
5 Second Cranking 1050 Amps
Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
20 hour rate: 3.5A/70Ah
5 hour rate: 11.9A/59.5Ah
1/2 hour rate: 87.5A/43.75Ah
CCA: 875 Amps
DIMENSIONS
SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
(Add 5/8 to height for battery post)
General POWER Series Specifications:
Temperature Range: -15 to +50 C
Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use)
I had it since april. Got it from bumpin buick. When i got it it looked bnib so id say less then a year. Ive charged it and had it on a mech 270. It has been maintained well
MiX
MiX
Topeka, KS
MiX
