Sold FS: Stinger SP800 Power2 Dry Cell Battery
rtillaree
F***, Strong
battery is maybe 7 months old, but its only been out of the box for 2 at the most...i used this to run a kx1200.1 and an md2 (at different times obviously) as well as several 4 channels and it worked great...its in excellent condition, just needs a good dusting...comes with case, case has been mounted so there are screw holes in the base...battery is reading a constant 15+ volts at this time...
Battery Type: Dry Cell
Max Peak Discharge: 2400 AMP
5-Second Cranking Output: 925 AMP
Cold Cranking Output: 470 AMP
Nominal Capacity: 30 Ah (C20 rate)
Diminsions: 7.1L x 6.7W x 5.6H
$110 Shipped
nope, thats the thing, i literally just pulled this out of my car when i posted it...only thing that been juicing it is my 190amp iraggi alt...everyone thought my readings were wrong on my terminals, but once we ran a volt meter to the alt we saw that it was putting out 15.5 steady...so +1 for iraggi i guess...
its hard to say what you would get per say, your going to get whatever your alt is putting out, should be 14.4 but it could be something else, higher or lower depending upon how efficient your alt is...but if your planning on a bigger system anything over a 1k sub amp and another amp for comps than a battery is a good idea, and this battery is more than efficient enough for a decent size system....
ttt...
rtillaree
F***, Strong
rtillaree
Orlando
jailhouseracer8
