Sold FS: Sony Basstube w/ built in Amp
bizflawless
How Fly
Up for sale is a Sony Mobile ES XS-TL1
Specs
63/4" Aluminum Cone Driver w/Rubber Surround1 ohm Voicecoil Matched to Digital Amp
Compact Vent-loaded Enclosure only 16" High
Vertical or Horizontal Mount Bracket Supplied
Preamp and High Level (speaker) Inputs
High Efficiency Class D PWM Amplifier
50W x 1Ch at 1 ohm
Adjustable 50-180Hz Lo-Pass Filter
Adjustable 50Hz EQ (0 to +10dB)
Adjustable Output Level & Phase
Speaker Section
Speaker Type
Impedance
Circuit System
Inputs
Outputs
Maximum Outputs
Rated Outputs
Input Level Adj. Range
Cut-off Frequency
Low Boost
Power Requirements
Current Drain
Frequency Response
Mass
Supplied Accessories
Woofer
16 cm (61/2"), Aluminum cone type
1 ohm
PWM (pulse width modulation) circuit
RCA pin jacks; high level input cords
RCA pin jacks (pass-through)
100 W
50 W (1% THD)
0.2 - 2.0 V (RCA pin)
0.8 - 8.0 V (High level input)
50 - 140 Hz
0 - 10 dB (50 Hz)
12 V DC car battery (negative ground)
At rated output: 5A
35 Hz - 200 Hz
Approx. 3.6 kg (16 lb. 15 oz.)
Parts for installation and connections (1 set)
Height: 405 mm (approx 1515/16 in)
Width (Diameter): 200 mm (approx 77/8 in)
A friend of mine had it in his car, adds a nice little thump to your ride...
Looking to get $100 shipped O.B.O NO REASONABLE OFFER WILL BE TURNED DOWN!!!!!
If you have it Friday I can do $50 shipped for it.I dont need it, but will put it in my car.
Let me know.....if you say its sold to me, I'll pay ya friday, otherwise, I'll see if you still have it by then.
Let me know.
alright just let me know, add $5 for paypal fees //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
bizflawless
How Fly
bizflawless
Houstatlantavegas/Mars
bizflawless
