fs: second skin deadener 80 spl tiles
c_b_
Second Skin SPL Tiles. 80 tiles.
Adhesive = Viscoelastic butyl rubber - 99.94% solids content
Weight = .79 lbs per sq. foot
Foil thickness = 10 mils (10/1000")
Total thickness = 80 mils (80/1000" - 2mm)
Sheet Size = 6" x 10" (.41 sq. ft. ea.) (32.8sq. ft. total)
$130 shipped. should be flat rate friendly.
entertain trades with 10 or 12 icon, xcon, q, id's etc
not looking to divide. you buy and use what you need then sell leftovers.
I will ship using USPS unless buyer pays for other services.
idk much bout the comparables. iirc, was supposed to be as effective with only 25% coverage compared to blanket installations.
Damplifier Pro and the SPL tiles are the same exact thickness.
The difference is the foil
Damplifier Pro - 6.5 mils - Black
SPL Tiles - 10 mils - Silver
Both products are 2mm thick (80 mils)
i just used Google
I had the SPL tiles in my Caliber. The backing wasnt very sticky, but it did work. Just needed some additional spray on adhesive. I swapped it out for the Alpha Damp. The AlphaDamp is way above anything else they make.
So is the price tag!
c_b_
c_b_
bluegrass st
supra94
