Sold FS- RD Audio 2200.1D Amp and Audio Control 3.1 EQ
cdf294
Hey guys.
I have some gear that I need to sell. Both items in great cosmetic condition (8.5-9/10) and 100% functional.
First up is an RD Audio 2200.1 amp.
I have heard that this amp doesn't do rated power- just not possible with only 120 amps worth of fusing. Having said that, it does produce a good amount of quality power and will move your subs fine unless you have something that refuses to move with 1500 watts.
Why am I sabotaging my own sale?
The last thing I want is for someone to feel mislead or cheated. The amp is very clean with only a few scratches at the mounting points. There is also one very small scratch on one of the end covers.
The amp works 100% and has no issues other than what I have mentioned.
Looking for $200 shipped in lower 48.
The next item is an Audio Control 3.1 Parametric EQ/Line driver.
I purchased this EQ new, but the wife went on a cleaning binge and tossed the box for it.
No noticeable scratches anywhere on this unit. All I have available with this is the plugs and 2 mounting brackets, one of which has been slightly altered (small notch cut out in top of mounting bracket). This is clean and 100% functional with no issues, again, other than mentioned.
Looking for $110 shipped in lower 48.
Now I must admit that the 3.1 had some hum. I installed the unit without hooking it up first and adjusting the ground isolator jumper for best performance. I had it installed in such a way that I would have to remove both seats and then remove the center console in order to remove the EQ. I lived with the noise due to the amount of work required to find the best jumper setting. If you buy this, PLEASE make sure you check this before permanent installation.
I have many pics available for those with interest. Just PM me.
OK guys.
I have done some measurements of how much room I actually have for a replacement amp (trade).... It's not looking too good.
I have had a few generous trade offers, but nothing offered will fit the space available or has the output I need.
It looks like I might have to reconsider my options here. I should probably just sell the RD amp, instead of trading, until I figure out how to deal with this.
The amp I have now is 11.25" long and 10" wide. The replacement amp cannot be more than 1" wider and/or 1" longer. It also must have the RCA jacks at the end of the amp (length, not width).
Here is where a replacement amp needs to fit (amp on left):
**** i guess i should have looked sooner i was in texas this weekend and prolly would have picked it up but i blew all my cash now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
cdf294
cdf294
Central Texas
cdf294
