Sold FS- RD Audio 2200.1D Amp and Audio Control 3.1 EQ
cdf294
Hey guys.
I have some gear that I need to sell. Both items in great cosmetic condition (8.5-9/10) and 100% functional.
First up is an RD Audio 2200.1 amp.
I have heard that this amp doesn't do rated power- just not possible with only 120 amps worth of fusing. Having said that, it does produce a good amount of quality power and will move your subs fine unless you have something that refuses to move with 1500 watts.
Why am I sabotaging my own sale?
The last thing I want is for someone to feel mislead or cheated. The amp is very clean with only a few scratches at the mounting points. There is also one very small scratch on one of the end covers.
The amp works 100% and has no issues other than what I have mentioned.
Looking for $200 shipped in lower 48.
The next item is an Audio Control 3.1 Parametric EQ/Line driver.
I purchased this EQ new, but the wife went on a cleaning binge and tossed the box for it.
No noticeable scratches anywhere on this unit. All I have available with this is the plugs and 2 mounting brackets, one of which has been slightly altered (small notch cut out in top of mounting bracket). This is clean and 100% functional with no issues, again, other than mentioned.
Looking for $110 shipped in lower 48.
Now I must admit that the 3.1 had some hum. I installed the unit without hooking it up first and adjusting the ground isolator jumper for best performance. I had it installed in such a way that I would have to remove both seats and then remove the center console in order to remove the EQ. I lived with the noise due to the amount of work required to find the best jumper setting. If you buy this, PLEASE make sure you check this before permanent installation.
I have many pics available for those with interest. Just PM me.
I might also consider trading one/both of these items for a small footprint mono, or 2 channel bridgeable amp, capable of 600+ watts RMS at 4 ohms.
The amp cannot be more than 12" long, due to my install (well, my current underpowered amp is 12"). I will have to take some measurements but may be able to squeeze a 14" amp in there. FYI, my current amp is a McIntosh so I would want something decent to replace it. And no, the 427 is not for sale- it will sit until I go 3 way active later in the year.
I guess I missed the obvious info. Sorry about that.
Yes, the amp is stable at 1 ohm and was used to run quad 8's at 1 ohm for around 8-9 months. If really don't know actual wattage as I never had it benched- If I had to guess, probably 1500w. The 120A of fuses should accommodate 1728w on 14.4v, so maybe you can draw a conclusion.
Never a problem with this amp, it's just too big for my install and i've gone to a lower powered SQ setup.
what are the frequency tunings of this amp - and what are the power and ground imput sizes ?
what would you expect this amp to put out on decent electrical @2.67 ohms ?
im running a trio of REx8s sealed and would like to try playing them in the upper 500hz range to see if they can do a bit of mid bass also
cdf294
cdf294
Central Texas
cdf294
