Sold FS random dropins
loudwhat?
The Sundown Audio King
ok i have some random dropins and i will give all specs but it is up to you to make sure it will fit if i know i will state what its for
First is:
this is a 18" D1 Nightshade dropin with a 4 spider option (2 hard 2 soft) 8 layer flat wound aluminum coil winding ASKING $90 shipped in the continental US coil OD is 83.0 MM ID is 76.42 MM length is 56.0 MM
spider is glued 84MM from bottom coil to spider landing
Next:
this is a 18" D2 Nightshade dropin with a 4 spider option (2 H 2 S) 8 layer flat wound aluminum coil winding asking $80 Shipped it has a small blem on the cone (just up from the dust cap on the left in the pic ) coil OD is 82.6 MM ID is 76.5 length is 57.0MM
spider is glued 84.MM from the spider landing to bottom of coil
Next:
this is a 18" D1 MT dropin it has 5 spider option (3 H 2 S) 8 layer flat wound aluminum coil winding asking $90 shipped coil OD is 82.3 MM ID is 76.0 MM length is 52.0 MM
spider is glued 84.5 MM from bottom of coil to spider landing
Next:
this is a 15" D1 it has 4 spider option (2 H 2 S) 4 layer flat wound aluminum coil winding asking $75 shipped it has a double former on the top coil OD is 80.0 MM ID is 76.0 MM length is 46.25MM
spider is glued 86.2 MM form bottom of coil to spider landing
loudwhat?
loudwhat?
statesville, nc
loudwhat?
