Sold FS: Quantum Audio 700 Class D mono $50 shipped
JustStoppingBy
"DoingStuffWell" of 2005
A little beat up, and scratched but works like a champ.
Quantum Audio 700watt Class D monoblock
Has slight scratches on the fins, but none broken. Has a sticker residue on the top left corner. Has a broken Battery + terminal so I was using crimped Spade terminals on a piece of 4 guage wire. It worked fine with an external fuse and POUNDED my Resonant Engineering 15 Se until the new amp got here.
50 bucks shipped. Its a great beater amp with a lotta life left in it. Can't do wrong for the price.
REFS in my sig, and I can accept Paypal or Money order... Paypal will be $55.00 shipped since I gotta dick with them.
Shipped insured with FedEx since I dont trust UPS
im drunk.. and its worth the 40 bucks plus shipping..
so we will see... id rather this guy meet me halfway with cash. if he's a no show.. then its yours for 45 shipped
^^ pms sent.
^ if you read the post..
With the broken battery terminal.. Ive been using (4) spade crimp ons placed in the FUSE terminals instead of the BATT +... Since everything I run gets fused at my Distro block, the Double 20 fuses were replaced with the power wire, and the Distro block had a 40 amp MAXI fuse on the power line. (not pretty, but if you pull the board, you will realize the Power trace on the board runs from the BATT + , through the (2) 20 amp fuses in PARRALEL and into the main power supply caps.
Component wise, its the same and still works the way it should. Once again... 50 bucks shipped for a working class D mono amp @ 700 watts aint bad. It moved my RE Sub pretty well..
Buy it or dont.. just dont post dump on me
Just dump a lil solder on the board and fix the terminal, 5 min job at max, hooking the amp up that way takes too long, ive done this before, but if your like me and unhook once in awhile, it is alot better to have a true terminal. Still at the price no one would have anything to b*tch about even if they did have to dump a lil solder in it. But looking at a amp for sale without fuses is a lil scary.
JustStoppingBy
JustStoppingBy
USF
JustStoppingBy
