Sold FS: Powerbass Amps
Here are the specs from the website:
• 4 ohm Power : 1000W x 1
• 2 ohm Power : 2000W x 1
• 1 ohm Mono Power : 3000W x 1 (manual says 3200 X 1)
• Strapped Power : 6200W
• Total Harmonic Distortion :
• Frequency Response : 10Hz - 400Hz
• S/N Ratio : >90 dB/W/M
• Damping Factor : >200
• Input Sensitivity : 0.3 - 8.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 50Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 45Hz
• Dimensions : 20.87" x 10.51" x 2.56"
These amps will also take 18V with no mods! They're strong amps. I have (8) of them but I only need (4) for my next project, so I'm selling the other 4.
Do you have any bench tests on them or any proof of output? Single 1/0 inputs?
I run them at 18V, so my numbers will be different then what you would expect to see unless you are also running an 18V setup.
I can tell you this though, they were benched to do 2700 at 12V @ 1ohm, and remember they can handle .7 on 18V, so there is no doubt they do more then their rated power.
weren't they 375 plus shipping in the other thread you posted too?
Yes they were, but on termpro I have them listed at $400. I figured I'd relist them one more time and if they don't sell then I'll just put 2 in my suburban, 2 in my 4runner and the other 4 I'll use on my next project.
What ohm will they take for burps and how much for two shipped to 30286?
It looks like about $30 for shipping via UPS ground, so about $780 for a pair. And on 12V you should have no problem burping them @ .5, may have to roll it up, but they will definitely burp @ .7 with no problems at all, even on 18V.
J B M
Team Pure Pressure
J B M
Palm Coast, FL
talon2nr7588
