POLK Audio/MOMO C300.2
Brand new, only taken out of plastic to drool over and then today to take these pics. Comes with everything they come with - manual, warranty card, sticker certificate......
See wattage certificate below, amp does more then rated (just like every Polk/Momo amp does)
150 watts RMS x 2 at 4 ohms
220 watts RMS x 2 at 2 ohms
550 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
Maximum Dynamic Headroom (MDH) power supply
requires 4-gauge power and ground leads
variable high- and low-pass crossovers, 50-250 Hz, 18 dB/octave
subsonic filter at 15 Hz, 24 dB/octave (only operates with low-pass filter activated)
6-way Smart System Protection circuitry guards against power and ground reversal, overheating and shorts, current overdraw, and low impedance
Pre-EQ switch optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers
RCA inputs accept both speaker- and preamp-level input (To use the inputs as speaker-level, you must attach RCA connectors to your speaker wire.)
preamp outputs
optional remote subwoofer level control
dimensions: 13-3/8"W x 2-9/16"H x 9-3/4"D
C300.2 features a Pre-EQ switch, which optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers!
$200 shipped
Don't have itrader feedbacks on CA but have them on diyma, caco and nissanclub all under the same name - Vital
preamp outputs
$200 shipped
