FS: Polk/momo Carbon C300.2 2-channel amp
  • 4
Vital
NY
POLK Audio/MOMO C300.2
Brand new, only taken out of plastic to drool over and then today to take these pics. Comes with everything they come with - manual, warranty card, sticker certificate......
See wattage certificate below, amp does more then rated (just like every Polk/Momo amp does)
150 watts RMS x 2 at 4 ohms
220 watts RMS x 2 at 2 ohms
550 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
Maximum Dynamic Headroom (MDH) power supply
requires 4-gauge power and ground leads
variable high- and low-pass crossovers, 50-250 Hz, 18 dB/octave
subsonic filter at 15 Hz, 24 dB/octave (only operates with low-pass filter activated)
6-way Smart System Protection circuitry guards against power and ground reversal, overheating and shorts, current overdraw, and low impedance
Pre-EQ switch optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers
RCA inputs accept both speaker- and preamp-level input (To use the inputs as speaker-level, you must attach RCA connectors to your speaker wire.)
preamp outputs
optional remote subwoofer level control
dimensions: 13-3/8"W x 2-9/16"H x 9-3/4"D
C300.2 features a Pre-EQ switch, which optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers!
$200 shipped
Don't have itrader feedbacks on CA but have them on diyma, caco and nissanclub all under the same name - Vital
^^^ Looking at your sig i see you're already familiar with Polk/Momo.
I had 6.5'' components for some time - these things were LOADED with bass while still sounding nice and clean everywhere else on frequency spectrum. Later on replaced them with Polk SR series.
would this amp be enough to run an 12" sr svc...believe the sr handles 700rms @4 ohm...i had talked to you awhile back when i had the barris 900.6 but had to sell due to money issues...now just looking for an amp to push the sr
SR svc subs are 700 rms at 4ohms.
This amp is rated for 550 rms and since it's underrated as certificate shows i bet i'll realistically do 600 rms at 4ohms.
So yes, this amp will work for svc SR sub just fine.
thats what i was figuring...i may pick this up from you if i can't work out a deal w/ a guy for a arc ks300.2 which will do the 700rms @ 4ohms...so ill get back to you soon...thanks
  • Locked
I am looking for the illusion audio C3 carbon's. I would prefer just the midrange as i already have a C6 componet set and I am looking to do a 3...
Vital
Vital
NY
Vital
    May 12, 2024
Brendon Jenness
    May 11, 2024
