Sold FS: Pioneer TS-W3001D4
ReDemoN
I have 4 Pioneer Premier subs for sale.
Have about 3 hours on them total.
There about 1 year old.
Dual 4 ohm
145 Shipped Each.
Will discount for multiples.
Thanks
Well I was gonna put the specs on the first post but you cant edit.
So here it is.
These are in great shape I really need to get rid of them.
Size 12"
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Integrated Single-Sided Silver Compression Terminals
Specifications
Watts MAX. Music Power 3000 Watts
Watts Nominal Power Handling 1000 Watts
Frequency Response 18 Hz to 700 Hz
Sensitivity 89 dB
Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
Recommended Enclosure 0.50 ~ 1.0 Cubic Feet
Dimensions 329 mm x 214.2 mm
Mounting Depth 188.8 mm
Accessory Grill UD-G307
ReDemoN
ReDemoN
Tifton, GA
ReDemoN
