FS Pioneer Premier DEX P1R SQ deck
Louisiana_CRX
dem shoes......
This is a very nice top of the line Pioneer Premier SQ deck that is loaded with features...Everything works perfect.....the display is bright...not dim like earlier models........It comes with Cage...trim ring...remote...tuning mic and manual....These use to cost $1000 back in the day....
$325.00 shipped....CONUS
FREE in CONUS
I also have the faceplate case ...here are some DSP specs......
Built-In DSP Features
13-Band Graphic Equalizer
4 Factory Presets (Rock/Pops/Vocal/Flat)
2 User Presets
Nuance Control
Auto-EQ - Automatic Frequency Response Calibration System
3 Curves Available (Dynamic/Natural/Mild)
Omni-Directional Microphone (Included)
Standard Mode (Sound Field Priority)
6-Mode Digital Sound Field Control (SFC) (Studio, Jazz, Club, Dome, Concert, Stadium)
Listening Position Selector (4 Mode: Front Left/Front Right/Front/All)
Front & Rear HPF: 50/80/125/200Hz, Level -24 to 0dB, Slope -12/-6/0dB
Subwoofer LPF: 50/63/80/100/125/160/200Hz, Level -24 to +6dB, Slope -18/-12/-6dB
Phase Switch for Subwoofer
Pro Mode (Digital Network Priority)
Time Alignment (0 ~ 160", 0.5" Steps)
Listening Position Selector (3 Mode: Front Left/Front Right/Front)
High HPF: 2k/2.5k/3.15k/4k/5k/6.3k/ 8k/10k/12.5kHz, Level -24 to +6dB, Slope -24/-18/-12/-6/0dB
Mid LPF: 2k/2.5k/3.15k/4k/5k/6.3k/ 8k/10k/12.5kHz
Mid HPF: 40/50/63/80/100/125/160/ 200/250Hz, Level -24 to +0dB, Slope -24/-18/-12/-6/0dB
Low LPF: 40/50/63/80/100/125/160/200/250Hz, Level -24 to +6dB, Slope -36/-30/-24/-18/-12dB Phase Switch for Low/Mid/High
If you change your mind on trades, I have a BNIB Custom TC Neo 18 built by Team PSI. Rated 1500 RMS. D1.4 coils with carbon fiber dustcap and direct connect leads.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
329
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
755
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
    May 16, 2024
    May 16, 2024
